Home > Maintenance & Mods (L322) > water temp gauge delay
dazk2001
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
noticed this morning the temps gauge was still on cold after driving around 5 miles after say 6 or 7 miles it came up to mid way is this normal or is there a sensor or stat problem
Post #670189 1st Aug 2023 4:34am
JayGee
Slow temp rise can be caused by a faulty thermostat that allows coolant to flow through the radiator during warmup. 2012 TDV8 Vogue (L322)
Post #670195 1st Aug 2023 6:59am
garyRR
Agree with JayGee. If the gauge does appear to be working and just seems delayed at warming up, this sounds like the thermostat. 2015 Range Rover Autobiography 4.4 SDV8
Post #670199 1st Aug 2023 7:16am
JayGee
Post #670207 1st Aug 2023 8:08am
dazk2001
thought about stat but temp gauge seems to all of a sudden go from cold to mid temp not a steady rise
also tonight i noticed it went to mid way then dropped of to cold again.
is the stat easy to get to might just change it 2008 Range Rover 3.6 TDV8 Vogue SE
Post #670251 1st Aug 2023 4:02pm
JayGee
PITA on the 4.4 as the whole coolant mixing housing has to be removed after taking out the main fan. Not sure on the 3.6? Parts shortages are common so you may not even get that far. Get a proper diagnosis first - could be a faulty temp sender or wiring or airlock in the coolant. 2012 TDV8 Vogue (L322)
Post #670253 1st Aug 2023 4:33pm
dazk2001
would the gap IID tool help to diagnose this ?? 2008 Range Rover 3.6 TDV8 Vogue SE
Post #670254 1st Aug 2023 4:36pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Yes. In live data look for "thermostat seal quality factor [%]". If value shows below 80% then you lost 20% of seal Wink
Post #670260 1st Aug 2023 7:03pm
JayGee
Yes. Watch the actual engine coolant temperature and it should go quickly to 89deg and stay there and not drop down when the car is cruising at speed and there is max airflow through the radiator. 2012 TDV8 Vogue (L322)
Post #670286 2nd Aug 2023 7:12am
