Home > Maintenance & Mods (L322) > water temp gauge delay |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Slow temp rise can be caused by a faulty thermostat that allows coolant to flow through the radiator during warmup. 2012 TDV8 Vogue (L322) |
1st Aug 2023 6:59am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Agree with JayGee. If the gauge does appear to be working and just seems delayed at warming up, this sounds like the thermostat. 2015 Range Rover Autobiography 4.4 SDV8 |
1st Aug 2023 7:16am |
1st Aug 2023 8:08am |
dazk2001 Member Since: 17 Jul 2023 Location: maidstone Posts: 24 |
thought about stat but temp gauge seems to all of a sudden go from cold to mid temp not a steady rise
1st Aug 2023 4:02pm |
PITA on the 4.4 as the whole coolant mixing housing has to be removed after taking out the main fan. Not sure on the 3.6? Parts shortages are common so you may not even get that far. Get a proper diagnosis first - could be a faulty temp sender or wiring or airlock in the coolant. 2012 TDV8 Vogue (L322) |
1st Aug 2023 4:33pm |
would the gap IID tool help to diagnose this ?? 2008 Range Rover 3.6 TDV8 Vogue SE |
1st Aug 2023 4:36pm |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 |
Yes. In live data look for "thermostat seal quality factor [%]". If value shows below 80% then you lost 20% of seal |
1st Aug 2023 7:03pm |
Yes. Watch the actual engine coolant temperature and it should go quickly to 89deg and stay there and not drop down when the car is cruising at speed and there is max airflow through the radiator. 2012 TDV8 Vogue (L322) |
2nd Aug 2023 7:12am |
