Home > General > coolant help please!
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
i am low on coolant - my 4.2 s//c reminds of this everytime I turn on the ignition. I go over to Land Rover dealer to buy more coolant but they don't have any stock of the pink stuff!!
Would anymore know what type of coolant is the pinkish stuff that that is in our radiators?
Since Land Rover malaysia are unable to sell me some, i might as well go to another shop to ask for a coolant with similar properties to the L.R variety.
Do anymore know specs the coolant is? any other brands that are good?
Since I live in the tropics, surely anti-freeze is not needed. But should it be mixed with water? at what ratio>?
thanks '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #73015 19th Jul 2011 7:33pm
the info's in our wiki....
Post #73018 19th Jul 2011 7:40pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
if it's what i think it is, it will be OAT anti freeze. this is organic stuff, red in colour and more expensive, but it is apparently what L/R recommend. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #73019 19th Jul 2011 7:42pm
pretlove
it is OAT and over here im sure its 50/50 mix but you might need to speak to the dealer to find out what mix yours needs to be.....also if you mix it with the blue stuff youll end up with a white sludge in your water system "RANGEISM WILL NOT BE TOLERATED"
Post #73031 19th Jul 2011 8:46pm
mercuryf1
thanks for the replies guys.
I have had a look in Wiki. It says: "Cooling system from dry inc reservoir tank is - refill 13L (13.7 US quarts) from dry 17.3L (18.3 US quarts)" 50% mix water with antifreeze Havoline XLC or similar extended life coolant. SLA Super Longlife Antifreeze
Is coolant and anti-freeze the same thing? I always thought that water is needed in the radiator to cool the motor down and we add anti-freeze to prevent water in the radiator from turning to ice. So now, do we need coolant + water + anti-freeze? '01 1.8i Freelander. Grey/ grey
Post #73064 20th Jul 2011 4:04am
Coolant and antifreeze are the same thing. Coolant would be the general name but with antifreeze properties. The pink OAT coolant has anticorrosion stuff in it and is organic so can go down the drain. MOre expensive and ment to last longer than the blue. You cant mix blue and pink due to their chemical make up as they produce a goo thats bad! You can put any pink/red/orange in with yours or do a full drain and flush and replace with cheaper more avalible blue. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #73065 20th Jul 2011 5:48am
As far as I remember American Marine Grand Banks motor yachts are made in Malaysia-Singapore and they will use it in there engines so it won't poison the water system in case of leaks. Should have it in vast quantities . 2008 MY Supercharged
Post #73070 20th Jul 2011 7:25am
