Home > Maintenance & Mods (L322) > Correct procedure on 2-post lift |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8206 |
You can do what you like to the suspension but it will always just drop to it's full droop, it will be fine and return itself to normal when let down, if you have height sensors that are nearing the end of their life they may fail but I have had L322's hundreds of time on a two post ramp with no issues....
8th Jul 2023 9:14am |
joel-h Member Since: 23 Sep 2018 Location: Kent Posts: 35 |
Thanks very much. Lift capacity is 3,500kg. I chose this lift specifically with L322 in mind.
8th Jul 2023 12:39pm |
Put it in off road height and it's easier to get under it to line up the arms... Pete
8th Jul 2023 1:32pm |
