Home > Maintenance & Mods (L322) > Correct procedure on 2-post lift
joel-h
England 2010 Range Rover Vogue TDV8 Ipanema Sand
Should I lock the suspension in off road height before lifting my L322 on my 2 post lift?
Also, if I can get the pads to line up with the jacking points, presume this is fine to lift on?
Post #668630 8th Jul 2023 7:06am
You can do what you like to the suspension but it will always just drop to it's full droop, it will be fine and return itself to normal when let down, if you have height sensors that are nearing the end of their life they may fail but I have had L322's hundreds of time on a two post ramp with no issues....
Jacking on the jacking points is fine as long as the rear points are not rotten like a lot of earlier 322's tend to be, if you haven't already it's a good idea to remove the plastic sill trims and check the sills and inner sills for rot, the plastic does a good job of hiding it.... Thumbs Up
If they are rotten then the front, outside, rear subframe mount is OK to use, jack the car a few inches off the ground and then give it a good rock to make sure it is OK...
Check the maximum lift of the ramp suits the 322, they are very heavy and a lot of ramps aren't up to the job... Pete
Post #668635 8th Jul 2023 9:14am
joel-h
Thanks very much. Lift capacity is 3,500kg. I chose this lift specifically with L322 in mind.
In the end we put it in off road height, not sure whether that made any difference or not! It’s a 2010 car so jacking points were fine.
Post #668658 8th Jul 2023 12:39pm
Put it in off road height and it's easier to get under it to line up the arms... Thumbs Up Pete
Post #668664 8th Jul 2023 1:32pm
