Home > Maintenance & Mods (L322) > Why you should ALWAYS drain oil; and don’t be a sucker |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 192 |
I did an oil and filter service on my L322 4.4TDV8 today. I used a Mahle filter and oil from Westway Lubricants. I got a 20L drum for £79.99 with free next day delivery. You really can’t beat that for value and I think they have a great reputation! I’m not sponsored or paid by them, I just think they do a great product at a fantastic price point!
28th Jun 2023 7:07am |
Probably not far off 1L in the second sump. You can’t drain independently as the two sumps are part of one system. There’s a ‘bridge’ between the two and the turbo sump is designed to retain oil at high inclinations so the turbos never go dry. However, I would recommend draining the main sump first as the turbo one can be messy due to the cross member in the way. Try and fashion some kind of funnel to minimise any mess. 👍 Andy
28th Jun 2023 7:55am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
I suck out the oil these days but remove the turbo drain reservoir plug every 2 or 3 oil changes. I've given-up removing the pipe for the main drain due to only getting a few drips after having done the suctioning. |
28th Jun 2023 9:33am |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 111 |
Where are the turbo sumps? If you drain the turbo sump are they fed fresh oil from the engine?
28th Jun 2023 9:50am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Turbo drain point highlighted in yellow/orange in my previous guide:
28th Jun 2023 12:01pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Mine gets removed annually for a full drain type service at Glenrands.
28th Jun 2023 1:22pm |
Thanks Gary, good to know👍👍 Kevin 2012 L322 Westminster 4.4 TDV8 1999 P38A 4.0 SE - Sold |
28th Jun 2023 4:11pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
How can that be? The oil flow to the turbo's comes from the main oil pump and that is fed from the main sump surely? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
28th Jun 2023 7:13pm |
BAZ8046 Member Since: 26 May 2023 Location: Chatham Posts: 22 |
Thanks Andy/Gary, that’s useful information.
28th Jun 2023 8:43pm |
The reservoir appears to prevent the primary turbo's drain pipe from emptying which would allow air up the drain as the pipe terminates below the fluid level. Both the 3.6's turbos drain to the reservoir but not the 4.4's secondary turbo. |
28th Jun 2023 9:22pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
Guys, dont take system wrong.
29th Jun 2023 7:33am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 395 |
Gary good to know as im going to be doing mine this month..............had a look at the sump plug it dont says its for range rovers but i take it it fits fine and no leaking ?
29th Jun 2023 9:11am |
Will - I don't think you need to worry. This is a 4.4 TDV8 specific issue.
29th Jun 2023 9:18am |
The 3.6 has both turbo drains feeding into a reservoir and not removing the drain plug is likely a contributor to failed 3.6 turbos. |
29th Jun 2023 11:35am |
