![]() | Home > Maintenance & Mods (L322) > Headlight bolt part number or size |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
Thread dia - Standard 6mm, length of threaded section - 16mm, you should be able to find a bagful of these on the net, if you only find standard types just use a washer with the bolt. |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
Cheers thanks, will try a standard M6 bolt. |
M6*16 went in spot on. Thanks |
