Home > Maintenance & Mods (L322) > Headlight bolt part number or size
Bingo_123
Guys,
Can anyone advise the part number or size of the headlight screw at the bottom for a 07 my tdv8.
There are 2 at the top and then there is a single cross headed screw at the bottom corner next to grill.
I dropped it inside the bumper, don't want to open the bumper for this screw.
I have tried in lrcat via wiki but there is no part no for that screw.
Please help with the part no or size
Thanks
Post #666285 9th Jun 2023 8:01pm
Merchy
Thread dia - Standard 6mm, length of threaded section - 16mm, you should be able to find a bagful of these on the net, if you only find standard types just use a washer with the bolt. Thumbs Up
PS - Use a blob of blutac or a bit of tape to hold the bolt on the tool for re-fitting, or magnetise the screwdriver / socket, if the bolt is not stainless.
Post #666288 9th Jun 2023 8:53pm
Bingo_123
Cheers thanks, will try a standard M6 bolt.
Post #666293 9th Jun 2023 10:10pm
Bingo_123
M6*16 went in spot on. Thanks
Post #666333 10th Jun 2023 8:22pm
