Home > Technical (L322) > 2010 NSR Driveshaft stuck in hub
Mattwales
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Ok, I know these can be a bit stubborn.
Put the hub assy c/w shaft in the press, 15ton with penetrant and heat. Not the smallest bit of movement.
Had anyone got any suggestions? I’d be most grateful.
Is it easier to get a new knuckle and outer CV?
Thanks,
Matt
Post #666051 6th Jun 2023 9:12pm
There is a special tool from LR. Bolts on the hub and winds out the shaft. Amazing bit of kit!
Post #666056 6th Jun 2023 10:51pm
Mattwales
I did try using the slide hammer in reverse essentially to achieve the same thing.
Would of thought the tonnage trumps the mechanical though?
Post #666061 7th Jun 2023 6:54am
I’ve never not gotten one out using that tool sir… Whistle Thumbs Up
Post #666065 7th Jun 2023 8:15am
