![]() | Home > Technical (L322) > Fuel gauge issues |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 528 ![]() ![]() ![]() |
The confusion, I suspect, results from different behaviour on earlier and later cars. As others have said, on a 4.4 you risk shutdown if you don't get it fixed. Presumably implemented in software to prevent upstream damage to other components.
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 737 ![]() ![]() |
On my 3.6 TDV8 the gauge started reading zero and as explained by others on here the car went into limp mode then shut itself off.
EOD Steve Member Since: 13 Feb 2023 Location: Lincoln Posts: 221 ![]() ![]() ![]() |
All noted.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Bring it to Wales and I could sort it. Suspect it'll be a bit expensive to cover my time and fuel to go to Lincoln. |
So I took the advice from the sage like forum members on here.
