Home > Technical (L405) > Westfalia Towbar
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Westfalia Towbar
Westfalia detachable towbar fitted today with 13pin electrics. Straight forward add and more than half the price the stealer wanted! L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #665263 27th May 2023 10:19pm
nambFFRR
Double result….
The dedicated electrics all work as expected without any coding! I’m one happy boy!
Regards
Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #665415 29th May 2023 5:22pm
Stick Legs
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Thanks for that, good to hear. I have just bought one to install.
I think it should be able to be completely concealed by the original non-tow undertray, will try anyway.
Cheers. Smile
Post #681573 31st Dec 2023 2:25pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Even though Im looking for an L322 fit can I ask you, when you bought the bar and ball did it come with the land rover plug on it? Ive emailed Westfalia to ask but havent had a reply yet
Thanks Current yokes
2012 4.4 TDV8 Westminster
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #681577 31st Dec 2023 2:51pm
Stick Legs
No idea, it's at my mate's garage waiting for me to go over & fit it.
I am led to believe it's plug & play. I paid extra to have the LED compatible 7 pin electrics.
I only tow horse boxes and car trailers so don't need 13 pin.
Will update once I have it.
Post #681589 31st Dec 2023 5:33pm
nambFFRR
Cheers. Smile
I managed to keep the original undertray but found the electric socket does foul the tray slightly. I gently warmed the panel and moulded the panel against the socket so it lays as flat as possible. Keeps the towbar and other stuff cleaner than having an open panel. I use the open panel when the towbar is being used to finish off the bumper/towbar L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #683486 21st Jan 2024 10:34pm
Stick Legs
Fitted but I cut my panel.
I am planning to relocate the plug with a welder to allow a smooth panel fit,
Will post pice once I get around to it.
Post #684757 4th Feb 2024 11:33pm
garyRR
Have just fitted the Tow Trust tow bar to my L405. I'm surprised how easy the job was (on my L322, it was a major operation).
All undertray remains. I found the two separate arms a doddle to fit around the exhausts when fitting.
I got the fixed tow bar trim from Land Rover. It was £37 Inc VAT and nicely hides the tow bar aperture and socket, whilst still keeping them accessible. 2015 Range Rover Autobiography 4.4 SDV8
Post #685496 12th Feb 2024 11:42pm
