Home > Technical (L405) > Restricted Performance again - codes downloaded
Jase71
United Kingdom 2017 Range Rover Vogue TDV6 Santorini Black
The annoying restricted performance light is back on. Just wondered if any of the attached codes point to anything specific?
 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #685190 9th Feb 2024 3:36pm
garyRR
Looks like an intake leak to me, causing the turbo to overboost and provide 'implausible' signals via the sensors to the PCM. The wrong air / fuel mixture will have a knock-on effect to emissions, so could cause the NOx fault.
I'd be pulling the MAP sensor out to see how dirty it is, and on the hunt for a split charge hose, intake hose or air intake manifold.
I'd also check the turbo actuator is working properly. At ignition on, it should perform a reset procedure which you can observe whilst someone turns the ignition on and off. 2015 Range Rover Autobiography 4.4 SDV8
Post #685495 13th Feb 2024 12:34am
