Home > Maintenance & Mods (L405) > Where do I recharge the air-conditioning on 3.0 2015 l405 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Dont do it.
26th May 2023 5:04am |
portrobc Member Since: 17 Mar 2017 Location: Evesham Posts: 63 |
I agree. I was in NI last week and went to use the a/c in earnest and it was just not happening. went to our local ATS and they emptied, tested, cleaned and refilled my system in less than an hour.
26th May 2023 7:31am |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 136 |
I really do doubt that trye outfits offer much in the way of a/c expertise.
26th May 2023 8:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
So how do you know how much is in the system, and how much to top off.....?? and BTW my 2014 is on R1234yf gas.. Pete
26th May 2023 8:38pm |
You either fill on weight having evacuated the system and then add in the OEM recommended charge which from memory on the L405 is 1kg.
26th May 2023 9:10pm |
To be fair, all they have to do is connect the machine up, the machine itself does all of the process. My local garage went on a course, bought the machine and the whole was so simple to do it was incredible. Vacuumed out, check for leaks, add the required weight of oil and gas, check pressures, job done.
Assuming the pressure sensors are working correctly
How do you know the OP is that plugged in? as stated earlier, the tyre fitters dont need to be plugged in at all, just the machine.
I've never heard of porous hoses, it's usually the shaft seal on the compressor that allows the leakage.
For me personally it's not worh the risk, I do install and vac / gas my home air conditioning units etc but the car is so cheap to have done properly without the guesswork. Agricultural dealers are usually a good source of AC service, my local company charges me £15 for vac out, leak check, oil and gas fill. They work day in, day out on the modern farm machinery nicely equipped with really big AC systems. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
27th May 2023 4:41am |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 134 |
Great info there Baz . Most helpful as my aircon has stopped blowing cold air, hoping it just needs topped up and not leaking X5 40d |
27th May 2023 6:39am |
I, in a previous work life was directly involved in the transitions from CFC's to HFC's in the early 90's and visited just about every compressor manufacturer in the World at that time.
27th May 2023 4:40pm |
Here is a site that discusses flexible hose coupling porosity to refrigerant gas, quoting Du Pont data comparing barrier hose performance to non-barrier hoses. I doubt it'd concern any tyre fitters at all but it makes for interesting reading especially if you have an older 911.
27th May 2023 5:33pm |
It was a somewhat interesting time with all of the new legislation being introduced
In EV's it also has very specific requirements because like a domestic fridge, the motor and compressor are hermetically sealed, no room for error with potential moisture in the system or oil that doesnt meet the insulation requirements for the 450v DC being applied to the motor. It's not a 'just stick any old oil in' scenario.
Its not something I've come across, every day a school day!
I have seen the flexible hoses of course but never attributed refrigerant loss through them, I assume the dye used to identify leaks cant get through the hoses, I've never seen it on any of my vehicles.
We perhaps have to disagree here, how much oil remains in the system? what about adding oil? The real danger of over filling and I have seen one of these kits used where it was overfilled and it blew the side out of the compressor when it hydraulic locked. So not quite the same as an air hose.
Thanks for an interesting insight, always something new to learn LOL. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
27th May 2023 5:54pm |
I used to have a 911 when I was in my 20's many moons ago, I never had a problem with the AC but I never knew about the leaks either. Interesting read. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
27th May 2023 5:56pm |
This is a bad case of operator error that will occur if you add in liquid rather than gas refrigerant. Similar to if you drive a car through a flood and suck water into the intake, my wife tried that once and pistons left through the side of the engine. The individual preforming the task must have inverted the can and this will suck liquid into the suction line and hydraulic the compressor. Something that will lead to catastrophic failure. If you shake a refrigerant service can or cylinder you will hear the refrigerant sloshing around, it is in its liquid state. So any DIY a/c recharge peeps, don't invert the containers and suck liquid refrigerant into your compressor. Follow the instructions of the can which do specifically state to keep the can upright and to rock gently to encourage the liquid to vaporise ensuring a good supply of gaseous state refrigerant into the suction line. Overfilling of refrigerant gas will not over pressurise an a/c system to destruction, it will deliver lots of warm air as there is not the evaporation level required within the evaporator to cool the cabin incoming air when a system is grossly overcharged. |
27th May 2023 6:11pm |
