Home > Maintenance & Mods (L405) > Where do I recharge the air-conditioning on 3.0 2015 l405
Smp68
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
Hi all my air-conditioning is not working well and I have some gas left over from a previous car to use up. Where is the low pressure point. I am having a thick afternoon and can't get wiki working. I have 2015 3.0 td v6 l405
Post #665064 25th May 2023 7:08pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Dont do it.
The remaining gas and oil needs to be removed so a very specific weight of refrigerant and lube can put in. The system should also be checked for leaks.
Local places like kwikfit offer a check and refill for £30, not worth risking IMHO. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #665088 26th May 2023 5:04am
portrobc
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Firenze Red
I agree. I was in NI last week and went to use the a/c in earnest and it was just not happening. went to our local ATS and they emptied, tested, cleaned and refilled my system in less than an hour.
They measure a specific amount of refrigerant back in to the system so I would not be happy interfering with it myself
Rob Now running a 2016 Autobiography plus a Bentley Continental GTC
Previously ran a Lincoln Navigator and 18 XC60 T5
Before that a pile of Jeeps, Mercedes and Jaguars and Porsches, Mustang and Volvo.
Post #665093 26th May 2023 7:31am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I really do doubt that trye outfits offer much in the way of a/c expertise.
I have done my own R134a or R1234yf top offs for over 30 years and its quick and easy. I could check and add refrigerant to my L405 sitting outside in maximum 10 minutes. The OBD even gives a pressure and evaporator temperature readout in real time. It'll tell you if the compressor clutch is engaged and you can see if its cycling or running as it should. I really doubt those tyre fitters are that plugged in.
On one car that I have owned for 25 years it does need a R134a top off every 6 years. Usually around 60 - 100g on a 660g charge. So it loses around 2% a year through hose porosity. 10 minutes every 6 years using about, at todays price, £5 of gas from service cans or £2 gas from larger cylinders. Little wonder the tyre fitters love topping off a/c systems.
My 2016 has the low pressure service port on the right side. Its a R1234yf fill system but I believe the 2015 is r134a. For anyone interested in servicing their own a/c system which does exclude total loss leaks then you can buy service cans (sub 1kg) of R134a without requiring a FGas certificate. For R1234yf no FGas is required. I have service cans and cylinders for both R134a and R1234yf ready to pull every 4 to 6 years at service time to top off the a/c system if required.
Post #665159 26th May 2023 8:21pm
So how do you know how much is in the system, and how much to top off.....?? and BTW my 2014 is on R1234yf gas.. Thumbs Up Pete
Post #665161 26th May 2023 8:38pm
baz000000
You either fill on weight having evacuated the system and then add in the OEM recommended charge which from memory on the L405 is 1kg.
Or, if you don't have access to a vacuum pump that pulls the gas out into an empty cylinder and weigh scales then you see what is happening on the running pressures using the OBD data or using a port coupled gauge set.
The website linked below gives the pressure guide for different ambient conditions for R134a. R1234yf is similar. For my L405 it was 1050kpa target evaporator pressure from memory for the ambient temperature that day. My car a/c wasn't working when I bought the car, it was only managing 680kpa. That was good, a relief, as having any pressure said there was still refrigerant in the system so I wasn't facing a a/c ending leak. So I monitored the inlet pressure on a low port gauge and checked the evaporator pressure on a high port gauge and confirmed with OBD data. I added gas until the specified pressure for the ambient temperature was obtained for both compressor inlet and outlet pressures. Result was a working a/c in comfortably under 10 minutes.
https://www.rechargeac.com/how-to/ac-system-pressure-chart/
There is lots of information online in videos and in write ups on how to perform DIY top off service on a car system. The only thing I'd recommend people avoid is the so called drop in replacements which are hydrocarbon blends. Those will not mix in the same way with the compressor oil as the original refrigerant. They are a fraction of the price to produce so offer savings but the solubility of the gas in the oil is critical for the compressor lubrication as the gas is soluble in the oil thinning it down considerably and also the oil entering the system does need to return from the evaporator and condenser back to the compressor.
Post #665163 26th May 2023 9:10pm
AJGalaxy2012
To be fair, all they have to do is connect the machine up, the machine itself does all of the process. My local garage went on a course, bought the machine and the whole was so simple to do it was incredible. Vacuumed out, check for leaks, add the required weight of oil and gas, check pressures, job done.
Assuming the pressure sensors are working correctly
How do you know the OP is that plugged in? as stated earlier, the tyre fitters dont need to be plugged in at all, just the machine.
I've never heard of porous hoses, it's usually the shaft seal on the compressor that allows the leakage.
For me personally it's not worh the risk, I do install and vac / gas my home air conditioning units etc but the car is so cheap to have done properly without the guesswork. Agricultural dealers are usually a good source of AC service, my local company charges me £15 for vac out, leak check, oil and gas fill. They work day in, day out on the modern farm machinery nicely equipped with really big AC systems. BMW i3 Electric Car
Post #665175 27th May 2023 4:41am
evotime
Great info there Baz Thumbs Up . Most helpful as my aircon has stopped blowing cold air, hoping it just needs topped up and not leaking X5 40d
Post #665180 27th May 2023 6:39am
baz000000
I, in a previous work life was directly involved in the transitions from CFC's to HFC's in the early 90's and visited just about every compressor manufacturer in the World at that time.
A bit of insight into some of the issues compressor manufacturers face with the gas and oil combo. The gas needs to be soluble in the oil as there is a lot of oil carried into and around the a/c system that must be returned back to the compressor otherwise it'd get oil starvation and die.
CFC molecular size is larger than the corresponding HFC so a bit of a problem with retrofit R12 to R134a systems was the R134a would pass through the rubber hoses at a much higher rate. The solution to this was to manufacture what were termed barrier hoses which are rubber hoses with a plastic insert. This greatly reduced the migration rate of gas out of the system and into the atmosphere but it never totally eliminated it.
Hose leakage has always been a factor in car a/c where fixed metal pipe coupling isn't possible due to flexing from a fixed condenser and a moving vibrating engine.
The refrigerant recovery equipment does do the work of evacuating, leak testing and refilling (on weight) a system. It doesn't need a highly skilled operative to work it. The machine does cost a bit of money though so for the DIY motorist it isn't a viable purchase but charging reading off pressures is a perfectly valid way to fill a system. It isn't high risk at all as that is how a refrigeration system works, pressurising the gas so it becomes a liquid that then evaporates to provide the cooling. Its no more risky than letting someone loose with an air hose to fill up their tyres. I have seen people confuse Bar for psi at Supermarkets and I wouldn't recommend that they go ahead and DIY their a/c system. Best to leave that to the tyre folk in that instance.
Post #665229 27th May 2023 4:40pm
baz000000
Here is a site that discusses flexible hose coupling porosity to refrigerant gas, quoting Du Pont data comparing barrier hose performance to non-barrier hoses. I doubt it'd concern any tyre fitters at all but it makes for interesting reading especially if you have an older 911.
https://griffiths.com/mr-ice-project/barrier-hose-upgrade/
Post #665234 27th May 2023 5:33pm
AJGalaxy2012
It was a somewhat interesting time with all of the new legislation being introduced
In EV's it also has very specific requirements because like a domestic fridge, the motor and compressor are hermetically sealed, no room for error with potential moisture in the system or oil that doesnt meet the insulation requirements for the 450v DC being applied to the motor. It's not a 'just stick any old oil in' scenario.
Its not something I've come across, every day a school day!
I have seen the flexible hoses of course but never attributed refrigerant loss through them, I assume the dye used to identify leaks cant get through the hoses, I've never seen it on any of my vehicles.
We perhaps have to disagree here, how much oil remains in the system? what about adding oil? The real danger of over filling and I have seen one of these kits used where it was overfilled and it blew the side out of the compressor when it hydraulic locked. So not quite the same as an air hose.
Thanks for an interesting insight, always something new to learn LOL. BMW i3 Electric Car
Post #665239 27th May 2023 5:54pm
AJGalaxy2012
I used to have a 911 when I was in my 20's many moons ago, I never had a problem with the AC but I never knew about the leaks either. Interesting read. BMW i3 Electric Car
Post #665240 27th May 2023 5:56pm
baz000000
This is a bad case of operator error that will occur if you add in liquid rather than gas refrigerant. Similar to if you drive a car through a flood and suck water into the intake, my wife tried that once and pistons left through the side of the engine. The individual preforming the task must have inverted the can and this will suck liquid into the suction line and hydraulic the compressor. Something that will lead to catastrophic failure. If you shake a refrigerant service can or cylinder you will hear the refrigerant sloshing around, it is in its liquid state.
So any DIY a/c recharge peeps, don't invert the containers and suck liquid refrigerant into your compressor. Follow the instructions of the can which do specifically state to keep the can upright and to rock gently to encourage the liquid to vaporise ensuring a good supply of gaseous state refrigerant into the suction line.
Overfilling of refrigerant gas will not over pressurise an a/c system to destruction, it will deliver lots of warm air as there is not the evaporation level required within the evaporator to cool the cabin incoming air when a system is grossly overcharged.
Post #665241 27th May 2023 6:11pm
