Home > Wheels & Tyres > Correct Storage of Spare wheel !
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hello Folks!
Finally managed to replace the space saver wheel on my 2012 Westminster with a full alloy. Tyre is a Michelin Alpin Winter, DOT 2016 from Germany, £55 and a wheel for £60.
I have removed the Space saver and packing spacers.
But when I put the full size spare in the well, its rubbing on the wiring loom. I have tried some foam underneath but have the same issue !
Am I m missing something ?
I will pop a photo on.
Post #664580 21st May 2023 8:19am
TeeMyob
Here
Post #664590 21st May 2023 10:35am
What size tyre is on said wheel sir?
Post #664592 21st May 2023 10:40am
PeteT80
Mine is General Grabber AT3 255/55/20 and have to deflate the tyre to about 20 psi, quite a snug fit.
Post #664596 21st May 2023 10:51am
TeeMyob
255/50/20 RR Westminster 2012 Standard fit
Post #664597 21st May 2023 10:51am
JayGee
The L322 was not designed to run the larger L405 size tyres so it's a tight fit for a spare. 2012 TDV8 Vogue (L322)
Post #664600 21st May 2023 11:25am
pcourtney
try and get a spare wheel lifting harness strap, or whatever they are called, just makes life a little easier in getting the Censored out
https://www.ebay.co.uk/itm/134477565395
Post #664648 21st May 2023 10:01pm
Vogue
Plus size for size a General Grabber AT is also a bit bigger than standard 255/55 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #664713 22nd May 2023 5:24pm
TeeMyob
thank you all again for your replies.
Great forum
Post #664739 22nd May 2023 9:47pm
