Home > Wheels & Tyres > Correct Storage of Spare wheel ! |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 200 |
21st May 2023 10:35am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
What size tyre is on said wheel sir? |
21st May 2023 10:40am |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 214 |
Mine is General Grabber AT3 255/55/20 and have to deflate the tyre to about 20 psi, quite a snug fit.
21st May 2023 10:51am |
255/50/20 RR Westminster 2012 Standard fit |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
The L322 was not designed to run the larger L405 size tyres so it's a tight fit for a spare. 2012 TDV8 Vogue (L322) |
21st May 2023 11:25am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 827 |
try and get a spare wheel lifting harness strap, or whatever they are called, just makes life a little easier in getting the out
21st May 2023 10:01pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
Plus size for size a General Grabber AT is also a bit bigger than standard 255/55 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
22nd May 2023 5:24pm |
thank you all again for your replies.
22nd May 2023 9:47pm |
