Home > Maintenance & Mods (L405) > Retrofit Adaptive cruise turn off on pre 2017 models ? NO
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Hi All,
On the 2017 facelift you can turn off the adaptive cruise by holding down one of the cruise buttons. Does anyone know if this function can be added to an earlier car ?
If you are happy to play follow my leader and stay in one lane on a motorway I guess it works ok but for anything else it is pants ! Mad 2016 AB SDV8 Barolo black
Post #664168 15th May 2023 1:24pm
lambo911
I guess from the lack of a response it is a no ! Very Happy 2016 AB SDV8 Barolo black
Post #664221 16th May 2023 8:13am
try a forum search.. ... - .- -.
Post #664226 16th May 2023 8:53am
I don't know of a way to do it.
I've seen threads on retro fitting it, which amuses me as I'm not a great fan of it, but not turning it off.
As a semi-permanent solution, I guess you could find a wire to the front radar sensor & remove that ? Or put some tape across it ?
Post #664229 16th May 2023 9:30am
lambo911
You can't ! Sad
Just had this reply from LR Retrofits
I don’t believe so as this functionality is built into the software and is not a configuration option. It certainly makes no mention of this on the online guide. 2016 AB SDV8 Barolo black
Post #664249 16th May 2023 12:52pm
If you try to disable parts of the system I would imagine it would fault the whole cruise control feature so nothing worked... Pete
Post #664254 16th May 2023 1:29pm
rstoughy
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
I looked at this also.
I find the adaptive cruse on mine borders on being dangerous. It was emergency braking while in the outside lane passing other cars so I just don't use it now.
Now I set the ASL and just use that.
Shame really as I quite like CC but live and learn I suppose.
Post #664391 18th May 2023 6:58am
this thread is for the L322 but might work on the L405,
https://www.fullfatrr.com/forum/post659664.html
also found this on the interweb,
Post #664396 18th May 2023 7:57am
GraemeS
The button holding procedure that someone with a L405 mentioned was to hold the distance reducing button for a few seconds after the minimum distance is shown which is only shown whilst ACC is enabled. I don't recall on which model L405 this worked though. I suspect ACC would be re-enabled on the next ignition cycle rather than permanently off, similar to the minimum distance resetting.
Post #664418 18th May 2023 12:52pm
Thanks gents - I'll give those a try.
As above, mine is OK some of the time, but on motorway bends it sometimes thinks a lorry in the middle lane needs some action so it beeps furiously and slams the brakes on. Censored knows what the cars behind think.
Post #664419 18th May 2023 1:19pm
GraemeS
Your radar unit must be more than just a little out of alignment. When I fitted my radar unit my eye-balling for staight ahead was good enough to prevent false alerts.
Radar alignment devices similar to headlight alignment machines are available so alignment could be checked prior to removing the bumper to adjust.
Post #664451 18th May 2023 8:46pm
I agree with Graeme, mine doesn't do that, I use it all the time and never had it slam the brakes on...!! Pete
Post #664463 19th May 2023 7:23am
comports
I assume the question is "Can I just have cruise control without the adaptive bit..?"
If so, not sure of the 2017 as I have a 216 but can you not justy turn off the front radar and then use Cruise as usual..?
I believe they are separate functions anyway. ie radar is just a 'collision warning alert' (which I can turn off via the dash menu) and I suspect if its off, cruise can't us it.?
I'll perhaps try later when I go out to check that cruise still works. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #664464 19th May 2023 7:47am
I'll have to have a look for the radar sensor.
It doesn't do it often and I have sort of leant to drive around it now - taking it extra wide around trucks.
I can't remember whether I've had it happen in the UK, so maybe it's something about driving on the wrong side.....
Post #664466 19th May 2023 8:46am
Comports,
Turning "forward alert" off has no effect on how the Cruise works, I don't have it on and my ACC and Queue assist work fine.... Thumbs Up
Alistair,
My old 322 used to pick up high sided lorries on a right curve and slow down, but never braked hard, funnily enough when abroad it didn't do the same with lorries on left hand bends... Pete
Post #664470 19th May 2023 9:29am
