![]() | Home > Technical (L405) > Terrain Control switch button replacement |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
They look similar to how computer keyboard button caps attach in that they are clipped on from above. To remove keyboard caps you simply give a short sharp pull using a tool that reaches under and hooks the bottom of the button to pull it upwards.
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 391 ![]() ![]() |
Thank you so much!!! Mike |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
you do know you can disable the stop/start.... ... - .- -.
SIMON1599 Member Since: 30 Jan 2022 Location: EAST YORKSHIRE Posts: 14 ![]() ![]() ![]() |
I certainly didn't know you can disable it off Stan.
here you go,
Hi Stan, So 2 weeks ago they installed a new terrain control switch on my wifes 2014. A week ago it did this, you start it and it turns off after about 3 seconds and won't turn back on which is ok i guess except when you pay about $400 to have it replaced you would want the whole thing functioning correctly but i like it off. |
d90110 Member Since: 22 Apr 2025 Location: USA Posts: 1 ![]() ![]() |
Help!
