Home > Technical (L405) > Terrain Control switch button replacement
funnyguy1
United States
I don't think I will get a response on this but i am pretty anal and try to keep the car a perfect as possible. The 1st thing i do when I start the car is turn off their "A OFF" button lower right. Consequently the white lettering is almost gone. I see some plastic button replacements offered on eBay that say "easy replacement. Here are 2 pics. I cannot see how the existing button comes off to install the new one? Has anyone ever done this? Thanks in advance! Mike
Post #664045 13th May 2023 11:45pm
fisha
They look similar to how computer keyboard button caps attach in that they are clipped on from above. To remove keyboard caps you simply give a short sharp pull using a tool that reaches under and hooks the bottom of the button to pull it upwards.
Look for universal key cap puller and you will see what I mean. V8 or else ...
Post #664057 14th May 2023 8:35am
funnyguy1
United States
Thank you so much!!! Mike
Post #664096 14th May 2023 4:26pm
you do know you can disable the stop/start.... ... - .- -.
Post #664111 14th May 2023 6:16pm
SIMON1599
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
I certainly didn't know you can disable it off Stan.
How do you do that?
Post #664119 14th May 2023 7:59pm
here you go,
https://www.fullfatrr.com/forum/topic52063...stop+start ... - .- -.
Post #664127 14th May 2023 9:09pm
funnyguy1
United States
Hi Stan, So 2 weeks ago they installed a new terrain control switch on my wifes 2014. A week ago it did this, you start it and it turns off after about 3 seconds and won't turn back on which is ok i guess except when you pay about $400 to have it replaced you would want the whole thing functioning correctly but i like it off.
Post #664384 18th May 2023 3:48am
