![]() | Home > Maintenance & Mods (L322) > Rear sub frame bushes |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1266 ![]() ![]() ![]() |
I've got a set of Genuine bushes sitting on my shelf in the garage and I'm waiting to pluck up the courage to get them changed.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Joe90 did an excellent write up here...
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
I bought the pulling kit of ebay and the correct bushes rather than the BMW ones, took me a day to change all four bushes, mine also had the rivets in that needed drilling out and replacing (2012 model)
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 ![]() ![]() ![]() |
I let me local Indy do mine |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 812 ![]() ![]() |
Alanm_3
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 410 ![]() ![]() ![]() |
Can anyone recommend a bush pulling kit?
Hi Rambles, I don’t think it was anywhere near that but it was the top hub bushes that were replaced, I’ll look out the invoice and let you know |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Hub bushes are definitely not subframe bushes |
Book time is around 6 hours, from memory. On a brand new car. With the JLR tooling. You'd have to be pretty lucky to achieve that on a 10yr old L322 ![]() |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
I've just done mine - took me about 4h.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Just about to do mine for the second time last time it was a full day might be easier this time |
