![]() | Home > Maintenance & Mods (L322) > How stiff should the COSV mechanism be? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi All!
This is the arm in question that appears to be against a very strong spring…
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Cheers Mike
Wasn’t there an engine ecu software update regarding the power dip between the turbo’s? 2012 TDV8 Vogue (L322) |
https://www.fullfatrr.com/forum/topic38291.html?highlight=cough
Possibly, yes. I remember it as the 80mph hesitation (as per the link from Baltic Blue) rather than a dip between the two turbos. I have purchased the IIDTool update for my ECU, however if I flash my car with it I loose my remap. If it fixes the issue for me then I am happy to then pay for the remap again… but would rather not do it and find it doesnt fix my issue. If I can get a definite “it will fix it” then I’ll go for it… For now I am looking at other areas (such as the hoses) as they can also be considered good practice to replace anyway; and if all else fails then I can still try the ECU update. The car hasn’t always done this so I do not see how the ECU flash would fix it for me. The change is more gradual as if something is wearing out, sticking, or not performing as it should be. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Baltic Blue, you had the update on your car? Before the update did you only notice it but around 80mph? For me it’s every time the engine passes the crossover point. For example, if i travel at 20mph, change the gear to be around 1,500 rpm, floor it…. The car accelerates as expected, has its lull in power and then picks up again when the 2nd turbo kicks in. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
