Home > Technical (L405) > Brake failure l405
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
Brake failure l405
Car 2013 4.4 autobiography
Driving my car yesterday I went to brake and the brakes failed , brake pedal traveled to floor luckily I wasn’t going fast and got car stopped when I got out there was a puddle of engine oil under car
Smoke coming from bonnet
Car recovered and waiting on it to be inspected and repaired under extended warranty does anyone know what could be the cause
I thought the oil was brake fluid but the AA and recovery men said it was definitely engine oil
Thanks in advance
Post #663791 10th May 2023 6:32pm
caymanblack
Bloody hell you were lucky! Unbelievable let us know the cause please. overfinch modified
Post #663794 10th May 2023 6:52pm
Dolphinboy
reckon brake master cylinder gone or leaky/corroded pipes?
Post #663796 10th May 2023 7:21pm
fisha
but why viewed as engine oil ? or was the aa guy just wrong ?
I cant see how an engine failure of oil coming out the engine would stop the brakes working in some way. The system should still have resistance regardless, even with the engine off.
Pedal to the floor implies that the master cylinder is pushing against no resistence ... ie, failed brake lines or cylinders ... irrespective of engine state, V8 or else ...
Post #663798 10th May 2023 7:27pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Did the engine stop? If the engine stops, you'll lose servo assistance and the brake pedal will take a mighty push to be anything near effective so can feel as if you haven brakes (but you will have a modest amount and need a lot of pedal pressure to produce it). Otherwise I cant see how loss of engine fluids would affect the(closed) braking system
ETA just reread your post OP and if the pedal went the floor, that wont be servo loss due to engine stopping. it suggests loss of brake fluid from the system First time FFRR owner
Post #663801 10th May 2023 7:38pm
Benner91
Hi pedal did go to floor engine never stopped
Engine sounded fine
Picture added of oil
The recovery guy started car sounded fine and drove easy up transporter ramp
Post #663803 10th May 2023 8:18pm
Merchy
Rather doubt that the pic shows engine oil, brake fluid has quite a different viscosity, it looks like the brake fluid has made the grey tarmac wet, ( and soaked in, as there is no puddle ) thus making it look black, maybe that is why the guy thought it was engine oil. A big leak somewhere in the brake system must be the cause.
Post #663810 10th May 2023 9:00pm
fisha
To be fair, that looks like engine oil at first glance. Even dirty brake fluid shouldn't really be that black in colour ... dark tea maybe, but rarely black. did you touch or smell it? easy to tell then. V8 or else ...
Post #663811 10th May 2023 9:01pm
Benner91
Yes the AA man touched it and said it was engine oil 👍
Post #663812 10th May 2023 9:07pm
Benner91
More photos of oil as car was moved away
Post #663813 10th May 2023 9:10pm
Gremlin500
Shocked Lucky boy! Glad you are OK.
As above, symptoms suggest a pipe or union gave out suddenly dumping brake fluid, so no brakes.
The brake system should have a double circuit so if one pipe fails, there is some residual braking.
If it’s oil, where’s the rest? You’d be in trouble with that little oil in the engine.
Interesting to get the final verdict on this one, and to know the exact cause & location of the issue, to further whet our FFRR paranoia Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #663821 10th May 2023 10:41pm
GraemeS
Australia
Many years ago my wife thought that our RRC had no brakes after a rear hose was broken by a caught stick. She was on a down-hill run to the front gate on our farm driveway on the side of a hill so had no option but to drive through the closed gate. Fortunately the bull-bar prevented damage to the car. In fact the 2nd circuit was still operative but very close to the floor giving the impression of no brakes at all with the pedal moving so far without resistance. I don't know if the RRC's brake system components are similar to the L405's but probably not as the RRC didn't have ABS.
Post #663822 10th May 2023 10:59pm
GraemeS
Australia
One needs to try to remember to pull and hold the park brake lever if the foot-brake fails as the ABS system will endeavour to bring the vehicle to a quick, controlled stop if the pump can get enough fluid, otherwise the park brake itself will be used.
Post #663823 11th May 2023 12:10am
AJGalaxy2012
Surely with dual circuit brakes, the pedal shouldnt have gone to the floor with a single fractured brake line, the likelyhood of both circuits fracturing at the same time unlikely? BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #663825 11th May 2023 4:09am
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Simple check of the brake fluid reservoir level will confirm the state of play.
Post #663844 11th May 2023 10:35am
