![]() | Home > Technical (L405) > Brake failure l405 |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1162 ![]() ![]() ![]() |
Bloody hell you were lucky! Unbelievable let us know the cause please. overfinch modified |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3215 ![]() ![]() ![]() |
reckon brake master cylinder gone or leaky/corroded pipes? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1450 ![]() ![]() |
but why viewed as engine oil ? or was the aa guy just wrong ?
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 508 ![]() ![]() ![]() |
Did the engine stop? If the engine stops, you'll lose servo assistance and the brake pedal will take a mighty push to be anything near effective so can feel as if you haven brakes (but you will have a modest amount and need a lot of pedal pressure to produce it). Otherwise I cant see how loss of engine fluids would affect the(closed) braking system
Benner91 Member Since: 18 Oct 2015 Location: Belfast Posts: 87 ![]() ![]() ![]() |
Hi pedal did go to floor engine never stopped Engine sounded fine Picture added of oil The recovery guy started car sounded fine and drove easy up transporter ramp
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
Rather doubt that the pic shows engine oil, brake fluid has quite a different viscosity, it looks like the brake fluid has made the grey tarmac wet, ( and soaked in, as there is no puddle ) thus making it look black, maybe that is why the guy thought it was engine oil. A big leak somewhere in the brake system must be the cause. |
To be fair, that looks like engine oil at first glance. Even dirty brake fluid shouldn't really be that black in colour ... dark tea maybe, but rarely black. did you touch or smell it? easy to tell then. V8 or else ... |
Yes the AA man touched it and said it was engine oil 👍 |
More photos of oil as car was moved away |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1656 ![]() ![]() ![]() |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2637 ![]() ![]() |
Many years ago my wife thought that our RRC had no brakes after a rear hose was broken by a caught stick. She was on a down-hill run to the front gate on our farm driveway on the side of a hill so had no option but to drive through the closed gate. Fortunately the bull-bar prevented damage to the car. In fact the 2nd circuit was still operative but very close to the floor giving the impression of no brakes at all with the pedal moving so far without resistance. I don't know if the RRC's brake system components are similar to the L405's but probably not as the RRC didn't have ABS. |
One needs to try to remember to pull and hold the park brake lever if the foot-brake fails as the ABS system will endeavour to bring the vehicle to a quick, controlled stop if the pump can get enough fluid, otherwise the park brake itself will be used. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Surely with dual circuit brakes, the pedal shouldnt have gone to the floor with a single fractured brake line, the likelyhood of both circuits fracturing at the same time unlikely? BMW i3 Electric Car
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Simple check of the brake fluid reservoir level will confirm the state of play. |
