Home > Maintenance & Mods (L322) > L322 2012 4.4 TDV8 Thermostst Housing Replacement
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I have a new thermostat housing being delivered next week and need some advice on changing it.
Is it installed without having to remove the fan shroud and fan to detach the hose connection to the thermostat, or can it be installed by just unclipping and detaching the three hoses at the front of the housing without removing the fan shroud and fan?
I have searched high and low for installation instructions to no avail.
All advice greatly appreciated as always.
John 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #663641 8th May 2023 1:27pm
JayGee
AFAIK you need to remove the whole fan and shroud to get access. If it's just a faulty thermostat then the small housing can be just swopped out without having to change the whole assembly which it comes with. 2012 TDV8 Vogue (L322)
Post #663647 8th May 2023 3:44pm
DrRob
Did you have problems sourcing it? Low supply currently.
Have you looked in the workshop manual on the Wiki page? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663648 8th May 2023 3:46pm
4434Morrison
@Dr Rob,
I have been speaking with my MD, they have about 40 on back order, some of which are due to arrive this week. My order has been given priority due to vehicle being off road...
I have checked the workshop manual, it gives great detail about changing the thermostat alone, which requires fan shroud and fan to be removed.
@JayGee,
Was hoping that the entire thermostat housing can be replaced without disassembling half the front end.
I have been quoted £1,000 for the thermostat installation. I dont mind doing the work myself for that sort of money. It should take no more than 6 hours or so...
Many thanks for the advice.
Post #663650 8th May 2023 4:24pm
DrRob
Good to hear that stock is coming through soon 👍
Do a write up with photos if you diy. It will be very useful for the forum 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663651 8th May 2023 4:26pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
it is possible to that without removing fan, but you dont want to do that this way. You spend lot of time trying to release tubes.
Post #663663 8th May 2023 6:09pm
4434Morrison
@Jimmie,
Thanks for your comment.... You are aware that this is the 2012, 4.4 TDV8 Jimmie?
Its not just the fan shroud and fan that has to come of to replace the thermostat on its own. The turbo actuator has to be removed entirely and the transmission oil cooler unbolted too.
I would also rather replace the entire thermostat housing together with the thermostat as a unit, rather than have the housing fail due to the plastic becomin brittle in due course.
Jimmie, do you have any advice specific to the replacement of the complete thermostat housing?
I appreciate that the plenum, throttle body etc will have to be removed and have no issue with that, as its a relatively quickly removed as I have recently replaced the oil cooler. and the turbo oil feed o-rings.
It doesn't seem to make much sense to have to remove the fan shroud, fan, turbo actuator and the transmission cooler to replace the thermosatat housing sitting in the V of the engine.
All further comments appreciated.
Post #663664 8th May 2023 6:29pm
MuddyTDi
Have the housings started coming through now? I need one but was told back order last week.
Post #664147 15th May 2023 7:24am
4434Morrison
@Muddy,
Sadly not yet, although my MD told me they would be available last week. Try Duckworths, they too said they were due to receive some last week, but no confirmation of availability as yet.
Post #664148 15th May 2023 7:30am
kevinp
Hope this is useful.
You don't need to remove the fan shroud, fan, COSV etc to get the coolant pipes off the thermostat housing.
I just unwound the fan and gently lifted it down and towards the radiator.
This then gives you enough room to remove the two 8mm bolts from the metal cooling pipe which then lets you pull the pipe off the thermostat housing.
Post #711012 4th Feb 2025 11:06am
