![]() | Home > Maintenance & Mods (L322) > L322 2012 4.4 TDV8 Thermostst Housing Replacement |
AFAIK you need to remove the whole fan and shroud to get access. If it's just a faulty thermostat then the small housing can be just swopped out without having to change the whole assembly which it comes with. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4314 ![]() ![]() ![]() |
Did you have problems sourcing it? Low supply currently.
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
@Dr Rob,
Good to hear that stock is coming through soon 👍
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
it is possible to that without removing fan, but you dont want to do that this way. You spend lot of time trying to release tubes. |
@Jimmie,
MuddyTDi Member Since: 13 Nov 2022 Location: Leeds Posts: 12 ![]() ![]() ![]() |
Have the housings started coming through now? I need one but was told back order last week. |
@Muddy,
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1263 ![]() ![]() ![]() |
Hope this is useful.
