Home > Technical (L322) > Diff replacement of 2006 4.4V8 Jag Petrol Engine
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
I am in the process of changing the front diff on the above car. Everything is completely unbolted and just need to remove it from the underside.
I am told that they can squeeze through the subframe. Does it go straight down or does it come out of the wheel arch? Help appreciated. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #663573 6th May 2023 4:05pm
dhallworth
Out through the wheel arch.
You need to lift it up and then angle it outwards bottom first and manipulate it out.
It’s a sh!t of a job but it can be done.
Post #663588 6th May 2023 9:54pm
Simon_CSK
David
Thanks, it was a sh!t of a job getting all the bolts out so what's new. Called it quits today and thought it best to sleep on it before tackling removal and refit. Current cars
Range Rover CSK
Discovery 3 HSE
Post #663589 6th May 2023 10:08pm
