Home > Technical (L322) > Trigger wire upgrade - few basic questions
fishyboy
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi all,
I am planning to do the trigger wire upgrade (wiring sketch below) using the method outlined by Ajmngn (Andy) this week and have a few remaining questions before I start:-
1) To access the starter motor do I just need to remove just the drivers wheel and wheel arch liner? Is there anything else I might need to remove to access the solenoid?
2) What is the best routing of the upgraded trigger wire through the engine bay?
3) What sort of connector/stud will I find at the starter motor (just to make sure I have something suitable on hand)?
Any other tips would be gratefully received.
Thanks to Andy for his advice to date.
Phil
Post #663603 7th May 2023 2:12pm
