Home > General (L405) > Does this look right?!
BurnsideDalesbreds
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
Hi Folks.
Looking for a bit of owner advice please. I’ve been looking at a 2015 SDV8 AB, this is a photo from the advertisement in which as far as my untrained eye can see, the vehicle is engine running at idle.
Concern is the red triangle warning light upper left and the suspension (I think) light lower left.
Would an experienced owner say these shouldn’t be there unless there’s an issue, or is it simply that that the photo has been taken before the lights have cancelled.
Apologies if it’s something obvious I’m missing.
Thank you in advance for any replies.
Post #663248 2nd May 2023 12:00am
MarianaWestminster
Most likely the red triangle is on as a door is open whilst the photo was being taken and the orange car in the bottom left shows the terrain reponse is in 'general' program.
If the terrain reponse knob in the center console is pushed down into 'auto' mode that orange car will dissappear but its not a fault.
Nothing to worry about I would say Thumbs Up
Post #663253 2nd May 2023 6:39am
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
I get that suspension symbol in auto mode too so yes looks normal to me. The empty tank and 0 miles of range is normal too Laughing
Post #663263 2nd May 2023 7:57am
fisha
^^^ Yup, normally after my wife has driven it for a few days, and then decides to take the other car to work.
If there are any warnings on the dash, it'll cycle through the messages for each of them on start up a couple of times, and they wont go away until you click OK ok the steering wheel. V8 or else ...
Post #663264 2nd May 2023 8:00am
TJH1985
Exactly this! That’s pretty standard for when my other half’s been using it as well Neutral
You would need to see it to be sure, but most likely just a door open as above. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #663268 2nd May 2023 8:22am
BurnsideDalesbreds
Thanks for all replies and info folks. Much appreciated. Hopefully I’ll be back with more questions….but no tales of woe….😂
Many thanks indeed 👍
Post #663592 7th May 2023 12:45am
Kot
Isn't there a point at zero fuel that the car is prevented to start? to protect the HP fuel pump? That would give some sort of dash warning also. 2018 SE SDV8 4.4 Byron Blue
Post #663595 7th May 2023 9:30am
JCW
The red warning triangle shows as soon as you hit the reserve fuel level. Jonathan
2007 Defender 90 XS Hardtop
Post #663596 7th May 2023 9:40am
