![]() | Home > General (L405) > Does this look right?! |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 696 ![]() ![]() |
Most likely the red triangle is on as a door is open whilst the photo was being taken and the orange car in the bottom left shows the terrain reponse is in 'general' program.
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 72 ![]() ![]() ![]() |
I get that suspension symbol in auto mode too so yes looks normal to me. The empty tank and 0 miles of range is normal too |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1425 ![]() ![]() |
^^^ Yup, normally after my wife has driven it for a few days, and then decides to take the other car to work. If there are any warnings on the dash, it'll cycle through the messages for each of them on start up a couple of times, and they wont go away until you click OK ok the steering wheel. V8 or else ... |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Exactly this! That’s pretty standard for when my other half’s been using it as well |
BurnsideDalesbreds Member Since: 01 May 2023 Location: Deepest Aberdeenshire Posts: 14 ![]() ![]() ![]() |
Thanks for all replies and info folks. Much appreciated. Hopefully I’ll be back with more questions….but no tales of woe….😂
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1277 ![]() ![]() |
Isn't there a point at zero fuel that the car is prevented to start? to protect the HP fuel pump? That would give some sort of dash warning also. 2018 SE SDV8 4.4 Byron Blue |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 895 ![]() ![]() ![]() |
The red warning triangle shows as soon as you hit the reserve fuel level. Jonathan
