Home > Technical (L322) > What parameters trigger DTC? (P0401-00)
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
So, every DTC has a range of parameters that will cause it to trigger. My question: is there a list of parameters/sensor readings that can let you know what might trigger a DTC?
I’ve been getting ‘P0401-00 (AC) Exhaust gas recirculation flow insufficient detected’ on my 4.4TDV8 intermittently but am almost certain that it’s not my EGR. Why? I had a brand new EGR fitted under warranty less than a year ago. I can’t rule it out, but let’s be honest, the chances are v low.
I’ve heard that the MAP sensor on top of the plenum can trigger it if it gets blocked. I’ve been keeping an eye on that sensor and keeping it clean so, unless the sensor is on its way out then I doubt that’s it. I’ve recently heard that the temp sensor in the EGR can also need replacing as the sensor sometimes doesn’t register heat very well if faulty/on its way out, and that will also register the fault. Both the MAP and EGR temp sensors may be red herrings but, the point is that there must be a number of different things that will trigger any particular fault; it can’t just be one parameter.
So, back to original question, is there a source that will tell me all of the different possibilities that can trigger a fault code?
Many thanks in advance as ever! Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #663244 1st May 2023 10:35pm
DrRob
Have you looked at the DTC chapter in the Workshop Manual? Free on the Wiki. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663254 2nd May 2023 6:53am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
put borescope camera inside egr tube and look gor soot. If you have bad / old injectors then it will give lot of it.
Post #663257 2nd May 2023 7:01am
Ajmngn
Thanks for the replies both. There’s little useful detail in the DTC Documents sadly. As I said in my OP, I’m not worried about the EGR as it’s not even a year old.
What I’m trying to ascertain is what list of triggers can cause this (or any other) DTC. As it’s an ECU-based decision, there must be something out there which would list all the possible causes for each possible DTC. Surely?
I heard that TOPIX has more info that the WM, so is there someone with access that might have a look to see what it says ref P0401-00?
TYIA Andy
Post #663259 2nd May 2023 7:16am
JayGee
Have you checked the short pipe that connects to the intake plenum for soot blockage? Also the ECU will try to increase EGR flow by closing the throttle plate to create negative pressure in the intake to pull more EGR gas through so if this is sticky / intake 'gunked' it may be the issue. (The commanded and actual throttle position and EGR position are viewable in the GAP IID tool BTW). Lastly an air leak in the intake will both cause more soot and prevent the throttle plate from creating a low pressure intake condition. 2012 TDV8 Vogue (L322)
Post #663262 2nd May 2023 7:42am
DrRob
There are a few places now that can "delete" the EGR and DPF Whistle Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663290 2nd May 2023 1:08pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Was the vacuum actuator changed as part of EGR valve?
I had the same code, my vacuum actuator had failed.
As part of diagnosis i checked operation of electric solenoid at the front of engine bay.
Post #664303 16th May 2023 10:23pm
Ajmngn
I have had the vacuum actuator changed when the new EGR was fitted. I haven't looked at the solenoid yet, but will see how easy it is to access when I get a chance to have a look. I assume you mean part no.10 on the picture?
I can't seem to find the part number for this for love nor money: it's not on any of the images on LRCat that I can see, nor on the https://parts.jaguarlandroverclassic.com diagrams. Do you know where I can find the part number in the event that I might need to source a replacement solenoid?
Either way, I've been monitoring the available live EGR parameters on my GAP tool and all seems to be in order - the commanded recirculation modulates nicely when driving and shuts off completely when under full acceleration and when the 2nd turbo spools up. Therefore, my suspicion is that the code is coming up as a nuisance code as the EGR seems to be operating fine from what I can see. As per the description in the WM list of Engine DTCs, I am beginning to thing that there's some corrosion either on the plug that connects to the EGR actuator motor, or at the engine ECU end. The problem is very intermittent and there seems to be no real correlation between driving and when the warning gets triggered. Sometimes it will be hundreds of miles and many weeks between triggering the fault, other times it can be a little as a few dozen miles and a a few miles. When I get a chance, I plan to take the plenum off for a thorough clean (as that's never been done) and I'll give the connections a good clean with contact cleaner and a scrape with something to clean the surfaces. I'll also test the resistance down the wires before and after to see if there's any difference.
As an aside, I had a problem with the passive fuel sender a few months back that was also triggered by corrosion on the wire causing high resistance to register an open circuit that triggered the fault. The DTC was intermittent at first, but progressively got worse to the point where I couldn't clear it and that's what caused me to troubleshoot properly and what led to me finding the issue. I won't know for sure until I do the same with the EGR wire but the symptoms are remarkably similar and the troubleshooting info in the DTC table also points to an electrical problem: short to power; short to ground; high resistance; or open circuit. As it's intermittent and doesn't;t seem to affect operations of the EGR, I highly suspect its resistance.
Anyway, I'll update as and when I have a chance to troubleshoot properly. Andy
Post #664331 17th May 2023 10:17am
Ajmngn
So, an interesting development this evening…
I was washing the car this eve and had a bit of extra time whilst still light so thought I’d try and see if I could access the electrical connector on the EGR Valve Motor (referred to as the Electric Actuator in the DTC Tables). I had to remove the pollen filter housing which is super quick and, lo and behold I could just about get to it with the bonnet in service position. BEWARE - don’t attempt this whilst engine hot as you will burn yourself!
I managed to unclip the plug with a pick tool and flathead screwdriver and, looking inside it was quite dirty. So, after plenty of contact cleaner and then pressing the plug back and then pulling apart about 20 times to clean the surfaces, I replaced it back in the EGR Valve Motor. There’s another plug about 15cm further up the branch that the first goes to and where it joins another bunch of wires from elsewhere, so I did that plug too. Anyway, the whole thing took about 10 mins to do. Easy.
Anyway, I thought I should do for a test drive and see if I could see any difference using the GAP tool to monitor the live values. So, I’ve either fixed it or f*cked it! I’m pretty certain it’s the former as all I did was put contact cleaner on the plugs and open and close them.
The GAP tool shows the values below and are what I’ve been keeping an eye on for the last week or so. The top two values were previously fluctuating between 0% when under hard load to about 50% almost constantly when driving. However, they did this until the engine had warmed up and then just went to 0% and stayed there this eve. That’s never happened before so, I have to assume that cleaning the contacts in the circuit has made a difference to the readings, which would make perfect sense if there was resistance through corrosion or dirt on the connections.
The bypass duty valve cycle is the vacuum actuator and is either 100% or 0% depending on whether you’re on or off the throttle which is as expected, and the other two values seem to remain fairly static as they did before.
Long story short, it’s clearly operating differently as a result of my investigation this eve so as I said, this is either fixed or f*cked. I’ll only know once I’ve driven lots more miles as, if the EML light stays off and the DTC doesn’t return, then I guess I must’ve fixed it! Fingers crossed for me!! 🤞
 Andy
Post #664379 17th May 2023 9:09pm
