Home > Technical (L322) > What parameters trigger DTC? (P0401-00) |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 192 |
So, every DTC has a range of parameters that will cause it to trigger. My question: is there a list of parameters/sensor readings that can let you know what might trigger a DTC?
1st May 2023 10:35pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Have you looked at the DTC chapter in the Workshop Manual? Free on the Wiki. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd May 2023 6:53am |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 162 |
put borescope camera inside egr tube and look gor soot. If you have bad / old injectors then it will give lot of it. |
2nd May 2023 7:01am |
Thanks for the replies both. There’s little useful detail in the DTC Documents sadly. As I said in my OP, I’m not worried about the EGR as it’s not even a year old.
2nd May 2023 7:16am |
There are a few places now that can "delete" the EGR and DPF Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd May 2023 1:08pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
Was the vacuum actuator changed as part of EGR valve?
16th May 2023 10:23pm |
I have had the vacuum actuator changed when the new EGR was fitted. I haven't looked at the solenoid yet, but will see how easy it is to access when I get a chance to have a look. I assume you mean part no.10 on the picture?
17th May 2023 10:17am |
So, an interesting development this evening…
17th May 2023 9:09pm |
