![]() | Home > My Range Rover > My L405 Maintenance and Modifications |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Interested to see how you get on with the ARB bushes, as the rubber ones seem to wear out fairly quickly. There is nothing that can't be fixed with a hammer😜😜
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Be interested to know if the ARB bushes are the same as the revised/new type? |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
+1 on ARB bushes.. watching this with interest. I’ve done mine twice |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
ARB and LED’s for me. Let us know please. |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 136 ![]() ![]() |
Not as productive as as first thought. Ended up up going away in the Van.
Extracting the oil via a suction pump will drain exactly the same as removing the sump plug as the drain tube 'is' the sump plug |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 739 ![]() ![]() |
I used the draper oil extractor on my previous 4.4 tdv8 l322 and my current l405 and had no issue removing the full volume of oil.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1317 ![]() ![]() |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 492 ![]() ![]() ![]() |
gee the corrosion in the longitudinal rails at the front really gets going eh? Has anyone replaced these or managed to protect them better? 2017 Range Rover Vogue V6 Diesel
The pump was fine, it kept going. It started sucking air which would suggest the sump was empty. I made sure nothing had moved or came lose and tried again still sucking air. I thought it weird so tested the pump in the waste oils and pumped fine. I searched YouTube and another guy had a similar outcome (not sure which pump he used). Will be removing the sump plug going forward to be 100% sure the sump is empty. Cant go wrong that way.
That's northern Scotland cars for you... I would seriously look at doing some corrosion prevention work asap! The brake lines are still crappy old steel! As well as the internals of the brake calipers, the drive shafts and several other parts under the cars...
Thanks for the info, will deffo start looking at preventative measures. Yeah, quite a low mileage car this which looks like its sat about a bit which doesn't help
The suction tube is attached to the sump where the drain plug would be so you can't get anymore out with that method ![]() |
