![]() | Home > Technical (L322) > 02-05 air suspension valve problems |
Could this thread explain your problem and offer a solution.
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
Thanks, but hopefully shouldn't be as this is a new compressor, plus the one in that thread is a different compressor.
Have I got it right that when selecting a lower ride height, the air is dumped from this brass valve, or is it on the compressor? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
iirc that is the PRV - pressure relief valve .
What should have been a simple job has turned in to a real pain in the arse. Had the new pump out several times and checked everything, nothing different happened except getting more trouble codes.
rover75lover Member Since: 02 Aug 2021 Location: wales Posts: 13 ![]() ![]() ![]() |
hi from what little i know ,the actual exhaust solenoid is mounted on the compressor head. this way the exhausted air is fed through the dessicant air filter .
Thanks for the reply. Bought a new compressor head and seal from AliExpress and it works perfectly, all on the old frame/air release valve. Still have no idea a new compressor alone caused so many problems on the old original frame . |
im no expert but that bi brass thing is an emergency relief valve . as someone said the ecu opens the valves and with the compressor off the air goes back through the dessicant and is vented to air . the cone shaped thing blocks often so yep drill a hole in it .
