Home > Technical (L322) > 02-05 air suspension valve problems |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
Could this thread explain your problem and offer a solution.
27th Apr 2023 3:02pm |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 |
Thanks, but hopefully shouldn't be as this is a new compressor, plus the one in that thread is a different compressor.
27th Apr 2023 3:22pm |
Have I got it right that when selecting a lower ride height, the air is dumped from this brass valve, or is it on the compressor? |
27th Apr 2023 5:46pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
iirc that is the PRV - pressure relief valve .
27th Apr 2023 6:51pm |
What should have been a simple job has turned in to a real pain in the arse. Had the new pump out several times and checked everything, nothing different happened except getting more trouble codes.
29th Apr 2023 2:55pm |
rover75lover Member Since: 02 Aug 2021 Location: wales Posts: 13 |
hi from what little i know ,the actual exhaust solenoid is mounted on the compressor head. this way the exhausted air is fed through the dessicant air filter .
28th Aug 2023 2:32pm |
Thanks for the reply. Bought a new compressor head and seal from AliExpress and it works perfectly, all on the old frame/air release valve. Still have no idea a new compressor alone caused so many problems on the old original frame . |
28th Aug 2023 2:44pm |
im no expert but that bi brass thing is an emergency relief valve . as someone said the ecu opens the valves and with the compressor off the air goes back through the dessicant and is vented to air . the cone shaped thing blocks often so yep drill a hole in it .
14th Sep 2023 12:46pm |
