Home > Maintenance & Mods (L322) > L322 6 Speed Gearbox plugs
this_is_anarchie
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Hi All,
Going to do a gearbox service on my L322 and want to buy new fittings. i can find a replacement drain plug but not fill plug. are these two the same (i.e. buy two drain plugs and use for both) or does anyone have links to both?
Thanks
this_is_anarchie Range Rover Vogue SE 3.6 TDV8
Post #662366 20th Apr 2023 11:20am
RRPhil
The filler/level plug (metal) and the drain plug (plastic) are entirely different.
Drain plug part no. TYB500020
Filler/level plug part no. LR007610 (M18 x 1.5mm)
The filler/level plug is the same one used for the earlier ZF 5HP24 transmission for the Range Rover and is sourced by ZF from a German company called Heinrichs. You can see that it has a built-in seal.
If you Google LR007610 you should have no trouble finding one.
Phil
Post #662373 20th Apr 2023 12:20pm
