![]() | Home > Maintenance & Mods (L322) > L322 6 Speed Gearbox plugs |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
The filler/level plug (metal) and the drain plug (plastic) are entirely different.
![]() Filler/level plug part no. LR007610 (M18 x 1.5mm) The filler/level plug is the same one used for the earlier ZF 5HP24 transmission for the Range Rover and is sourced by ZF from a German company called Heinrichs. You can see that it has a built-in seal. ![]()
If you Google LR007610 you should have no trouble finding one. Phil |
