Home > Maintenance & Mods (L405) > Dynamic Mode |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
Anybody bought the Dynamic Mode update from here...
18th Apr 2023 1:11pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1368 |
If installed / upgraded, how would you be able select dynamic mode when its not listed as an option on the terrain response dial physically?
27th Apr 2023 6:30pm |
You buy a terrain knob from a Sport which has Dynamic mode, it has an extra setting..... Pete
27th Apr 2023 7:07pm |
Apparently if you buy the switch you can just enable Dynamic mode in the CCF... I haven't looked yet though... Pete
27th Apr 2023 7:09pm |
hmmm interesting.
27th Apr 2023 10:04pm |
This is the standard one...
28th Apr 2023 7:38am |
I dont drive mine fast enough to think it'd be worth it. .... had it on the evoque and didn't notice that it made that much of a difference under spirited driving. Plus, I hated how the evoque cluster turned red ... as per the advert for the L405 does as well.
28th Apr 2023 10:10am |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 769 |
I’ve got dynamic mode on mine and use it when I want the anti-roll to kick in straight away (plus roll is helped by the suspension being slightly firmer), which is doesn’t when terrain response is in auto. MY23 Panamera E-Hybrid
28th Apr 2023 11:37am |
Cheers, do you notice any other difference...? Pete
28th Apr 2023 12:00pm |
Max94L405 Member Since: 27 Jan 2023 Location: Hampshire Posts: 41 |
I’ve found the traction control to kick in more often when cornering which it wouldn’t do in auto/ normal mode. |
28th Apr 2023 6:03pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
I can tell the difference on the Mrs's evoque. I do find the red dash irritating though.
29th Apr 2023 7:26pm |
