Home > Technical (L405) > SDV8 strange noises
Foster2018
United Kingdom 2018 Range Rover Autobiography SDV8 Carpathian Grey
SDV8 strange noises
Hi all, been in land rovers ever since i started driving, and recently made the jump from a dsco 4 to a sdv8.
i have 2 questions, one is i have a rattle i can here in the cabin, thats annoying, is from the engine, and only under acceleration, its subtle but annoying. also can be heard louder under the car.
second and more worrying is a creak/bang when mannovering at slow speeds of pulling from a roundabout etc. sounds like something is binding, then letting go?
do the rear brakes ever bind on these? or prop shaft issues?
could be bushes but would be a bit odd when it happens for that.
other thoughts is gear box but doesnt seem to be when gears change
Any help would be muchly appreciated
Thanks
Tom
Post #661731 13th Apr 2023 8:43am
the rattle could be a loose exhaust shield.. ... - .- -.
Post #661733 13th Apr 2023 8:53am
Seatown
Scotland 2013 Range Rover Vogue SE SDV8 Firenze Red
Could well be the shield under the gearbox. Mine is making this noise so I'll be looking at this fix shortly.
Couple of threads on here.
https://www.fullfatrr.com/forum/topic61199.html
https://www.fullfatrr.com/forum/topic64447.html
Post #662364 20th Apr 2023 11:03am
It is fairly common for the rear callipers to seize, just see if the wheel is hot after a trip, be careful it could be very hot... Thumbs Up Pete
Post #662372 20th Apr 2023 12:17pm
fisha
Binding could be the transfer case needing oil replaced and recalibrated … it can bind and release on sharp corners due to the different wheel rates when cornering. Noticeable on things like pulling moderately out of a junction when on a sharp steering angle.
Binding callipers are more likely to show when pulling away from standing still or coming to a stop. They’ll release with a thud, but less likely to make sounds when moving around a roundabout. V8 or else ...
Post #662401 20th Apr 2023 6:20pm
fisha
Oops double post V8 or else ...
Post #662402 20th Apr 2023 6:20pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
The bang at low speed manoeuvring could the front lower control arm bush. Tends to happen more when going lock to lock, braking while turning like lining up for a driveway etc. Cam
2011 TDV8 Vogue in Stornoway Grey
Post #665278 28th May 2023 8:48am
Foster2018
thanks all its under landy warranty so will be booking in with them! to investigate Smile
il let you know the outcome
Post #667547 25th Jun 2023 7:25pm
