![]() | Home > Technical (L405) > SDV8 strange noises |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
the rattle could be a loose exhaust shield.. ... - .- -.
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 ![]() ![]() ![]() |
Could well be the shield under the gearbox. Mine is making this noise so I'll be looking at this fix shortly.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
It is fairly common for the rear callipers to seize, just see if the wheel is hot after a trip, be careful it could be very hot... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1416 ![]() ![]() |
Binding could be the transfer case needing oil replaced and recalibrated … it can bind and release on sharp corners due to the different wheel rates when cornering. Noticeable on things like pulling moderately out of a junction when on a sharp steering angle.
Oops double post V8 or else ... |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 139 ![]() ![]() ![]() |
The bang at low speed manoeuvring could the front lower control arm bush. Tends to happen more when going lock to lock, braking while turning like lining up for a driveway etc. Cam
Foster2018 Member Since: 13 Apr 2023 Location: West Sussex Posts: 11 ![]() ![]() ![]() |
thanks all its under landy warranty so will be booking in with them! to investigate |
