![]() | Home > Technical (L405) > Key signal weaker |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8405 ![]() ![]() ![]() |
I remember reading something about having to use branded batteries as the cheap ones don't have the voltage... worth a check, it might be that easy... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35525 ![]() ![]() |
this pic shows the receiver locations, if one is compromised then it could possibly cause a problem,
recordman Member Since: 08 May 2013 Location: Kent Posts: 116 ![]() ![]() ![]() |
My car was parked near an enormous communications mast (south of Newbury) over the weekend and it played havoc with both locking/unlocking and starting. Had to stand close to the car before it would lock/unlock and place the key under the steering column to get the car to start, it then kept displaying 'smart key not in car'. I was sure that it wasn't a key battery issue as I had recently replaced the battery.
Rrsport2020 Member Since: 31 Dec 2020 Location: Uk Posts: 35 ![]() ![]() |
Thanks, this is helpful. Do you know if this is still applicable to the 2019 modules? Also where I could find further info such as part numbers. Car was with land rover for 2 week and the replaced one aerial but it’s no better. They now just say nothing is showing a fault and they aren’t interested and are blaming the immobiliser Could try another dealer I think the aerials / transmitters are quite cheap so may just order a few and try to replace them myself. Signal is defo worse at the front of the car |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1157 ![]() ![]() ![]() |
Oh, I see it's not the Dealers fault even though the problem started after they had the car. |
