Home > Technical (L460) > How to disable keyless entry
Phil.
Open drivers door and keep it open. Place the key fob to the RHS of the steering wheel and next to /touching the dash.
Press the lights on button (bottom left) on the key fob 3 times followed immediately by the unlock button (top right) once. Press all the buttons quickly and in succession. There is no response to confirm the change has occurred.
This also prevents the gesture tailgate feature from operating. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #661346 8th Apr 2023 12:36pm
RDR
That’s a top tip Thumbs Up
I would love to have the dealer disable it so insurance would acknowledge it. I simply don’t use the feature. MY23 PHEV HSE
MY19 Disco 5 HSE - gone
My16 Disco 4 HSE LUXURY - gone
My12 Disco 4 HSE - gone
MY05 Disco 3 S - gone but not forgotten
Post #661359 8th Apr 2023 4:14pm
Much better than the dogs triggering the gesture tailgate when open at a shoot... Rolling Eyes Banging Head
Post #661389 9th Apr 2023 12:45am
calicoj
Spain
If you leave your car unlocked, yeah, but otherwise, wouldn't the dog need to be holding the keyfob for that to happen?
Post #661495 10th Apr 2023 1:24pm
d3rm0
Re: How to disable keyless entry
I can’t get this to work, is the ignition on or off? Are you sure it’s the right hand side of the steering wheel?
Post #661951 15th Apr 2023 12:47pm
Phil.
Ignition off. I tried both sides and the RHS next to the dash/wheel worked for me. Literally touching the dash.
All the button presses need to be in quick succession. There is no response when the change occurs. If the indicators flash at the end then it hasn’t worked,
Took me a couple of attempts. MY23 D350 HSE
Post #661953 15th Apr 2023 12:56pm
Westminster
And how do you know when it's worked, you can't unlock the car by pressing the button on the door handle to unlock it with the key in your pocket?
Post #674844 3rd Oct 2023 11:41pm
Yes that’s correct sir… Approaching the car with the key in your pocket, it won’t unlock when you pull the handle. Or lock when you touch the lock button on the handle… 👍
Post #674856 4th Oct 2023 9:27am
Westminster
I just tried this and it worked first time. Key held on dash on right side of steering wheel, almost touching steering column and an inch below the screen.
I couldn't get the boot to open with gesture before hand but now pleased it can't happen by mistake.
Post #674931 5th Oct 2023 12:33pm
Phil.
Great stuff! MY23 D350 HSE
Post #674932 5th Oct 2023 12:41pm
Eirik34
Norway
What is the difference in disabling keyless entry this way versus doing it through the screen menus?
In the menu you can specify if the doors should unlock when approaching and/or lock automatically when leaving. You can disable either or both of these through the menu.
Post #675807 18th Oct 2023 1:34pm
Phil.
I don’t think the screen menu option was available when I took delivery of a MY23 earlier this year.
I wanted my keyless function fully turned off for security reasons, plus I prefer to use the fob to unlock/lock the doors.
I assume the screen menu option doesn’t fully turn off the keyless function, only partially? May be the boot sensors remain active using the screen menu even if the doors are inactive? It’s worth checking. MY23 D350 HSE
Post #675808 18th Oct 2023 1:42pm
Eirik34
Norway
Just tested the Powered gesture tailgate when the vehicle was locked and with the keyfob in my pocket. And it worked just fine - tailgate opened without the doors being unlocked! Personally I think that is a usable feature.
Post #675869 19th Oct 2023 10:33am
I thought the 460 was different to the 405 and you didn't have to worry about the unlocking as you can't capture the key code and retransmit it to open the car... And no need for a faraday pouch either....
Or did I read it wrong...? Pete
Post #675897 19th Oct 2023 4:22pm
Phil.
From a LR PR release:
“State-of-the-art keyless technology brings added cyber security and convenience with advanced Ultra Wide Band (UWB) transceivers preventing thefts from copycat devices. Jaguar Land Rover was the first vehicle manufacturer to introduce the pioneering keyless entry system and New Defender uses the innovative set-up to resist relay attack and meet the world’s toughest security standards.’’
There is also a movement detector in the key that switches it off in the house, meaning there is no need for a Faraday pouch.
However, note it says ‘resist’ not ‘prevent’. How long before the scum and their technology catch up? And it doesn’t prevent a CAN bus attack. You need a Ghost or similar immobiliser to hamper such an attack.
https://media.landrover.com/2019/technology-21st-century-defender MY23 D350 HSE
Post #675903 19th Oct 2023 5:59pm
