![]() | Home > Technical (L322) > Cold mornings |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
WOW, i thought this would be the place to find someone who had had similar problems with cold starting RR 2005 4.4 petrol
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Before starting the car, turn ignition on for 10 seconds then off. Try this two or three times then start the car... See what that does sir? |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
I've never experienced any problem with cold starting our 3.6TDv8 at upto -10C (140,000 miles)
thanks for your replies
Sorry Knares,
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Spark plugs been changed and measured properly recently?
My point was to check if the fuel pump was week and loosing pressure overnight… 👍 |
thanks fellers, i will check on those things RR 2005 4.4 petrol
