Home > Technical (L322) > Cold mornings
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
Cold mornings
Cold mornings
Hi
Lately we have had some really cold mornings (Australia)
Around -0c,
When I start the car, it starts as normal, but stops immediately
It dose this two or three times before it continues to run and then it runs verry rough
After its warm it runs fine
Any ideas where I should start looking
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #668179 3rd Jul 2023 3:41am
knares
WOW, i thought this would be the place to find someone who had had similar problems with cold starting RR 2005 4.4 petrol
Post #668707 9th Jul 2023 4:12am
Before starting the car, turn ignition on for 10 seconds then off. Try this two or three times then start the car... See what that does sir? Thumbs Up
Post #668710 9th Jul 2023 4:49am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I've never experienced any problem with cold starting our 3.6TDv8 at upto -10C (140,000 miles)
The glow plugs should do the job if given at least 10s as suggested by Craig.
It's best to wait until Glow Plug warning light goes out & then turn the key further to start the car.
It might take even longer than 10s at very low temps & is quite short at what are probably more typical Aus temps.
If still not starting well, might be worth checking the glow plugs Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #668715 9th Jul 2023 7:59am
knares
thanks for your replies
this is a petrol car
BMW M62 engine
i didnt think it had any heaters ?? RR 2005 4.4 petrol
Post #668716 9th Jul 2023 8:22am
Pawl
Sorry Knares,
Should have paid attention and noticed your signature !
Petrol engines I think only rely on the temperature sensors to tell the engine ecu to inject more fuel.
If you've got diagnostics, it's probably worth checking what the temperature sensor readings are when you're doing a cold start.
A friends cold start issues were all down to a failed temp sensor. The engine ecu then assumes a default value which is probably well above zero. Paul,
Post #668728 9th Jul 2023 10:36am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Spark plugs been changed and measured properly recently?
I had a similar thing with my m62 engine. Mine turned out too be the rocker cover gaskets had failed and let oil into the spark plug chamber so made it slightly harder too start over the winter as the plugs had become slightly damp
Allen
Post #668741 9th Jul 2023 1:02pm
My point was to check if the fuel pump was week and loosing pressure overnight… 👍
Post #668747 9th Jul 2023 3:59pm
knares
thanks fellers, i will check on those things RR 2005 4.4 petrol
Post #668773 10th Jul 2023 2:24am
