Home > Technical (L322) > Broken locking wheel nut key. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
This morning I attempted to adjust the handbrake on my FFRR, but was thwarted at the first stage.
9th Jul 2011 12:27pm |
Locking wheel studs should not be tightened up fully, only nipped up until they are secure |
9th Jul 2011 12:42pm |
Sadly the last person who had the wheels off was not aware, and probably over tightened it with his windy gun
9th Jul 2011 1:13pm |
Not much help I know but I never use locking nuts they only give you untold grief like this case and if a thieving pikey has a jack capable of lifting a Range Rover high enough to nick your wheels then they are going to have the were with all to get a locking nut off . 2008 MY Supercharged
9th Jul 2011 1:19pm |
agreed, if it was not for the cost of a set of replacement tyres at over £1K, and the fact the wheels share the same stud pattern with some BMW's and VW's, I would probably replace them with normal nuts.
9th Jul 2011 1:23pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
This happened to me on my D3 but I damaged the lock nuts so bad I could'nt get them n off. However worse still I had just fitted stormer 20inch wheels which I didnt like so I had replaced with 19inch wheels to find out two of the wheels i couldnt get of because of the damn locknuts. So I drove about with two stormer 20s and 2 x 19s on the car feckin nightmare. Two options and this does work believe me. Remove all the other nuts and drive the car around in a circle slowly what should happen is the nut will crack and dont worry the wheel wont come off . Once you hear the crack you can eaily remove the nut. This is a method used by some landrover garages apparently to remove stubborn or damaged locknuts. Despite trying this on the second locknut I couldnt get it to budge so I brought is to a Quickfit and they burned it off with a torch without damaging wheel. Needless to say since then I take locknuts off and replace with normal ones. Hope that helps. Present :2008 TDV8 HSE
9th Jul 2011 2:35pm |
That sounds like a sure way to oval the wheel nut holes to me Gone - Range Rover Supercharged 2006 |
9th Jul 2011 4:54pm |
Justin
9th Jul 2011 6:55pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
You can get a socket set that will undo locking wheel nuts, they use pins and shape to the nut as required. Ring around a few garage one will have a set. 2004 black Vogue TD6 |
9th Jul 2011 9:56pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Gator sockets?
11th Jul 2011 9:41am |
yep thats it, one of them. 2004 black Vogue TD6 |
11th Jul 2011 8:28pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 866 |
That tool won't help! They're a rubbish design and the problem isnt grip, it's the outer sheath spinning. They are a pig to get off from direct experience. See the below post and pic of my own nut that had to be attacked with a grinder, chisel and scaffolding bar!
12th Jul 2011 7:55pm |
It's booked in to be sorted this thursday, I will post back with an update when I get the car back. I'm seriously thinking about ditching the locking wheel nuts to avoid tis happening again. Gone - Range Rover Supercharged 2006 |
12th Jul 2011 7:58pm |
Paulo Member Since: 28 Sep 2010 Location: Glasgow Posts: 199 |
I'd ditch the Locking Wheel nuts too....
13th Jul 2011 8:25am |
