Home > Maintenance & Mods (L322) > Lower Tailgate Straps…..
mjdronfield
Hi,
Searched the threads but can’t find any definite info…. Moving house today… and the LH lower tailgate strap has started to give way. Quite common….
I’m trying to find which part numbers I need… I have the damping kit as it’s a 2011. Some list the straps as LR038051 and say x2…. But then some list that as 2002 to 2010…. Some don’t. Are they different each side if the damper strut is fitted?
Cheers
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #660513 27th Mar 2023 8:58pm
Phoenix
The ones you need have a nipple on top of one of the bolts - I have a spare one (f.o.c.) at work if you need it.
Post #660517 27th Mar 2023 9:15pm
mjdronfield
That’s a lovely offer Iain, many thanks. I will take you up on that if I can.
Is the nipple extra just for the side with the damper and the other side the normal part number as above do you know? LH one has failed and I think the dampened side is RH, but that won’t be far behind failing I would imagine.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #660523 27th Mar 2023 9:36pm
They are different, Robin sourced me a pair for my last 322, as stated the drivers side one has a bolt with a nipple on the end for the damper... Other than that they are the same... Thumbs Up Pete
Post #660526 27th Mar 2023 9:47pm
Phoenix
The nippled one will fit both sides, but you only need it on the offside. I'll check in the morning - I may well have more than one. Let me know if you want it/them posting or you could nip in to my work and I'll fit it/them, only takes a few minutes.
Post #660528 27th Mar 2023 9:51pm
Discotigger
The tailgate cable part numbers are:
LH Cable: LR017462 / LR038051
RH Cable: LR017461 / LR038048 (This one has the nipple for the damper)
Make sure you get genuine LR or Britpart Cables, as a lot of the ones advertised are the wrong lengths. I got my two cables from Island 4x4, bit more pricey than the 'fleabay' cheapies, but they fit correctly.
Post #660534 27th Mar 2023 10:30pm
Rusty Nuts
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Hello chaps - on the topic of the straps - I took the damper and strap off my 2011 TDV8 last night to check the damper strength.
The “ nipple “ bolt came undone easily but the captive nut end in the bodywork fell out and into the body cavity.
It was too late in the day to look further but has anyone come across this before and is there a quick fix ?
I tired a forum search last night but failed to find any answers .
Thanks ,
Andrew.
Post #660571 28th Mar 2023 1:48pm
Epson Green
Perhaps a Rivnut could be the solution, better than having to weld a nut to the panel👍 Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #660650 29th Mar 2023 4:30pm
Rusty Nuts
Yes - thanks for the suggestion. I had been wondering if I could use a rivnut. I need to check the size of the hole it has left me to play with .
Post #660651 29th Mar 2023 4:34pm
