Home > Maintenance & Mods (L322) > Lower Tailgate Straps….. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
Hi,
27th Mar 2023 7:58pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The ones you need have a nipple on top of one of the bolts - I have a spare one (f.o.c.) at work if you need it. |
27th Mar 2023 8:15pm |
That’s a lovely offer Iain, many thanks. I will take you up on that if I can.
27th Mar 2023 8:36pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8362 |
They are different, Robin sourced me a pair for my last 322, as stated the drivers side one has a bolt with a nipple on the end for the damper... Other than that they are the same... Pete
27th Mar 2023 8:47pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The tailgate cable part numbers are:
27th Mar 2023 9:30pm |
Rusty Nuts Member Since: 06 Jan 2021 Location: Shropshire Posts: 58 |
Hello chaps - on the topic of the straps - I took the damper and strap off my 2011 TDV8 last night to check the damper strength.
28th Mar 2023 12:48pm |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 113 |
Perhaps a Rivnut could be the solution, better than having to weld a nut to the panel👍 Kevin
29th Mar 2023 3:30pm |
Yes - thanks for the suggestion. I had been wondering if I could use a rivnut. I need to check the size of the hole it has left me to play with . |
29th Mar 2023 3:34pm |
