Home > Wheels & Tyres > Will 275/45/R20 all terrains work?
EOD Steve
United Kingdom 2012 Range Rover Vogue TDV8 Sumatra Black
Hi all,
Just doing a bit of forward planning for when the L322 is bought.
Would appear VSE / WESTMINSTER / AB pretty much all have 255/55/R20 tyres.
I want GG AT3………OR similar……..
Seems as they don’t do above size (in the UK anyway).
Quick google search suggests 275/45/R20 might be available.
Any thoughts?
Post #660353 25th Mar 2023 10:13pm
wayneg
As you want AT tyres I presume you will be doing some off-road driving. Get tyres with the highest and strongest sidewall possible, 45 profile will not give you the best footprint when tyres are deflated for offroad driving. I run 275 55 R20
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #660358 26th Mar 2023 12:11am
Vogue
275/45/20 AT work perfectly - I ran General Grabbers AT’s in that size on 2 of my 322’s - very capable tyre and near enough the correct rolling radius. Absolutely no rubbing issues on std wheels. The tyre sidewall is virtually the same as the std 255’s as the 275’s are wider and sidewall depth is a % of the width.
For what it’s worth I now run 285/50/20 in the winter on the L405 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #660365 26th Mar 2023 8:07am
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I’ve run these tyres on two l322`s now with no issues at all.
 Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #660368 26th Mar 2023 9:25am
EOD Steve
Thanks for the replies.
I only just noticed them, after I just posted another very similar question! Doh.......
s
Post #660400 26th Mar 2023 2:41pm
EOD Steve
Re: Will 275/45/R20 all terrains work?
Thanks for the reply. My off roading will be limited to campsites and low key trails while touring GB. Nothing serious at all. But just like AT tyres on such a car. Steve
Post #660401 26th Mar 2023 2:43pm
EOD Steve
See below. Thanks mate.....
s
Post #660402 26th Mar 2023 2:44pm
Vogue
As an option, You may want to consider the Cooper AT3’s they are noticeably quieter than the Generals… 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #660437 26th Mar 2023 8:43pm
EOD Steve
Thanks I will check them out
S
Post #660440 26th Mar 2023 8:58pm
