![]() | Home > Wheels & Tyres > Will 275/45/R20 all terrains work? |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 801 ![]() ![]() ![]() |
As you want AT tyres I presume you will be doing some off-road driving. Get tyres with the highest and strongest sidewall possible, 45 profile will not give you the best footprint when tyres are deflated for offroad driving. I run 275 55 R20
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3767 ![]() ![]() |
275/45/20 AT work perfectly - I ran General Grabbers AT’s in that size on 2 of my 322’s - very capable tyre and near enough the correct rolling radius. Absolutely no rubbing issues on std wheels. The tyre sidewall is virtually the same as the std 255’s as the 275’s are wider and sidewall depth is a % of the width.
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
I’ve run these tyres on two l322`s now with no issues at all.
EOD Steve Member Since: 13 Feb 2023 Location: Lincoln Posts: 221 ![]() ![]() ![]() |
Thanks for the replies.
Thanks for the reply. My off roading will be limited to campsites and low key trails while touring GB. Nothing serious at all. But just like AT tyres on such a car. Steve |
See below. Thanks mate..... s |
As an option, You may want to consider the Cooper AT3’s they are noticeably quieter than the Generals… 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Thanks I will check them out
