Home > In Car Electronics (L322) > Rear entertainment unit does not instruct
AJ Johnny
Hi, help appreciated if you can.
2011 Autobiography with limosene seating. It has the rear control unit with lcd screen so the rear passengers should be able to select what they want to hear or see.
Everything in the rear works if selected from the front screen.
The rear controller charges and responds to all button presses on its own screen but the car system does not respond.
I have checked the permission for rear seating control, no difference.
The rear headsets work so the infrared sensoe is working, I don’t know how to test the receiver.
Any thoughts?
Post #660347 25th Mar 2023 10:10pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
I know this is of no help, but I the same problem happened to my 12 month old Disco with the rear entertainment. Shortly afterwards it all packed up. I took it back to the stealers & it was fixed within a day and I think it was down to one wire, but either way both problems were fixed & it was all fine after that. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #660352 25th Mar 2023 10:55pm
AJ Johnny
Thanks for the reply, it holds promise of some sort.
Post #660354 25th Mar 2023 11:19pm
