| | Water ingress and audio failure |  |
 Good afternoon all,
After a massive downpour here I was the victim of the dreaded water ingress into the LH rear electronic stack (now fixed - fingers crossed) MY10 L322 5.0 NA
 As a result, I've lost the radio, parking sensors, GPS directions, CD, aux input,... basically, everything that makes a noise apart from the touch screen beep, and the engine (that still makes a very nice noise!)
 For those that have been in a similar situation, what component was it that failed?  The BT module seems fine (visually) and bypassing it does not seem to fix anything, the amp was a similar result and the MOST loop is still broken even when the amp is bypassed.  The parking module did have water in it but has been cleaned and dried and I don't see how this would affect the MOST system.  My local Independent LR expert said to take the stack out and clean every pin on every plug so that's this weekend's job.
 I can access the #753 menu but don't get any info from that as it's "out of range".  The water only got into the back corner so it's something there, but not sure what.  Don't want to replace all the modules to determine which one it is as that's getting a bit expensive...  How did others go?
 PS tried the "hard reset" and now am stuck in 2009!
 Thanks & regards,
 Eddy
